| Home > Help Needed / General Tech Chat > Why lower cr on n/a engine than turbo?? | ||||||
27th Mar, 2005 at 09:48:28pm
Just gotta a+metro engine No 12he72 104126,I checked it on mini resources site and its unleaded 9.1 cr,Turbo block is 9.4 Baffled.(can't afford the 18cc 73.5 je's at mo)
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
27th Mar, 2005 at 10:28:34pm
stuart wright has been using dished standard pistons for some time , it was running 18 psi bost which gave 182 bhp on the rollers last visit, make sure the pistons have drillings around the oil control ring grove rather than a slot , the je's are deeper dish , the ones i have seen required an amount to be ground of the top of the rod as there was not enough clearance obove the pin -!! not ideal Edited by stuart gurr - vmaxscart on 27th Mar, 2005. |
28th Mar, 2005 at 02:59:41pm
Stuart,
28th Mar, 2005 at 03:51:26pm
Unleaded Metro Engines
28th Mar, 2005 at 04:13:49pm
So according to that list, a 12HE24 or maybe a 12HE72 could be an 8.0:1 CR OR a 9.1:1 CR???
28th Mar, 2005 at 04:18:30pm
http://www.manchesterminis.co.uk/technical...ngine_types.htm
28th Mar, 2005 at 10:55:52pm
Take it as a 9.4 then,would it have the same pistons fitted as a standard turbo.
28th Mar, 2005 at 11:55:11pm
Standard Turbo pistons have a 12cc dish.
29th Mar, 2005 at 12:28:10am
Interesting stuff, I've seen some MPi heads that definately had at least 23cc - and these looke to have a pretty meaty deck aswell - ideal for turbo chambers!
29th Mar, 2005 at 01:13:20pm
metro = class x
29th Mar, 2005 at 03:14:08pm
WTF?
29th Mar, 2005 at 04:05:12pm
bottom of the 1st post dave |
29th Mar, 2005 at 04:12:58pm
29th Mar, 2005 at 07:15:26pm
yep i had a mpi head which had 23 cc dish as well as 33mm inlets, pity i had it worked on for my NA 1380 ended up with 19cc, 37, 29.3 valves but still never mind. always looking for them bigger bunches of bannanas |
