| Home > Help Needed / General Tech Chat > Sand Blasting | |||||||
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
27th May, 2011 at 08:26:38am
Hi guys
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
27th May, 2011 at 08:33:25am
we use the stuff from machine mart but i've heard in the past it could be worth heading down to your local powder coater as he may well sell you a bag of something much cheaper.
27th May, 2011 at 10:57:39am
I bought a portable Sealey a few weeks ago.
27th May, 2011 at 11:15:28am
I haven't used the portable one yet but the old man said it was ok, but not brilliant.
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
27th May, 2011 at 11:25:53am
On 27th May, 2011 stevieturbo said:
I bought a portable Sealey a few weeks ago. To say it's pathetic is an understatement. Although the handle/trigger assembly seemed to be blocked when I got it, air wouldnt even pass through. And the drilling from trigger to outlet is physically impossible to access to try and clear. I did get it moving some air, but the output wouldnt strip anything. I'm guessing that isnt normal ? When just pumping air, how free flowing should the trigger be ? or when blasting, just how much power should it have ? I bought this one a few years back: And if it's similar to what you've got, then it doesn't sound normal to me - the trigger on mine pulls easily enough, and air should flow very freely - Certainly as free (if not more so!) as a blow gun, you should feel the whole 90psi or so!! As for how good it is, well negligable really. If you're expecting to strip paint/rust/etc quickly and easily over a panel or large surface - then this is not up to the job at all, and it will certainly seem pathetic. If you've got a couple of small rust patches to do, or are blasting small things then it does the job eventually - but will empty the whole 1lt sized pot of grit in around 30secs or so - and will use a lot of air doing it too, so it won't be as quick as you would probably imagine or wish it to be!! |
27th May, 2011 at 12:54:57pm
I also find the more the grit is used the less effective it becomes |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
27th May, 2011 at 07:08:51pm
If your using it to remove rust, then forget glass beads, they do a nice job of finishing things, but theyre not up to the job of actually removing rust... might be alright for stripping paint off panels if you go very carefully and use very little pressure, but to be honest i wouldnt recommend it.
And on the 7th day........... God created turbochargers! |
![]() 130 Posts Member #: 9395 Advanced Member |
27th May, 2011 at 10:10:31pm
I've got a Sealy SB993 and it works OK if you remember a couple of things
Edited by ntm1275 on 27th May, 2011. |
27th May, 2011 at 11:29:19pm
Thanks for the info.
28th May, 2011 at 06:55:04pm
Mine was the SB992
28th May, 2011 at 10:49:11pm
I'm lucky to have access to a couple of blasters at work. The small one uses white abrasive "sand" and is OK for very delicate stuff but slow for anything of any size.
29th May, 2011 at 10:19:04pm
On 28th May, 2011 Tom Fenton said:
I'm lucky to have access to a couple of blasters at work. The small one uses white abrasive "sand" and is OK for very delicate stuff but slow for anything of any size. The big one uses steel broken shot and is a monster, if you accidentally point it at your hand it hurts like hell even through the thick rubber glove. Makes cleaning awkward things a 2 min job! Seen a film the other night, bank robber thing with your man Jason Statham in it. The baddies tortured a guy to get info out of him using a shot blaster. When you think about it....that's really got to hurt !!! 9.85 @ 145mph
29th May, 2011 at 10:26:30pm
the blast we use at work is 8th high/wide, uses steel shot get stuck inside and it ll skin you alive, not good for anything delicate though. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
