Home > General Chat > Wow I got the hang of the search button =D
Craigie-B
Member #: 9468
Wootton Bassett
Just wanted to say that the reason im beign so quiet atm is because I actually got the hang of the search button. I've already found the answer to ALL of the questions I needed over the past two or three days just by searching - furthermore I also found the turbo plumbing diagram which is VERY helpful.
Thank you guys for all the info youve put on this forum!
Craig
bennyy
Member #: 9037
Doncaster, yorkshire
you can find everything you neeed to know using the search.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wintersurferuk
Member #: 2208
This is one of the best forums ive used. theres some much info about everything to do with a mini.
good luck!
Craigie-B
Member #: 9468
Wootton Bassett
yeah im finding that aswell :)
jimmy
Member #: 829
essex
Craig
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7194 this helps too :)
Edited by jimmy on 29th May, 2011.
1293 Turbo mini
