Home > Beginners Tech > remote mount manifold (side mount)
wez
Member #: 9271
Stoke on Trent
ive been thinking about the various options obviously i could make 1 from scratch, other option is to modify an lcb type manifold. but while thinking about the latter i was wondering if a injection type cast manifold could be used and the just make the downpipes sweep out the the side of the block.
would this be a good idea? or should i just continue sourcing a couple of knackered lcbs to have a play with?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
You can weld cast to mild steel, but in that scenario I don't see it lasting very long.
wez
Member #: 9271
Stoke on Trent
it wont need welding as the downpipes on the injection mani are bolt on, thats what got me thinking about it. picture pinched from a certain site.
Edited by wez on 29th May, 2011.
It would take whole load of horrid bends to get both tubes anywhere near your turbo
wez
Member #: 9271
Stoke on Trent
when i picture it i see probably 110 deg bend out of the manifold and then straight to the turbo (x2) i know once i started to do it it would get a bit more difficult. but that was how i saw my idea if that makes sense?
Advantage
Member #: 1450
Near Paris - France
I does for me as I was planning to do the same (but was thinking about using the injection downpipe modded)
Rusty by nature
wez
Member #: 9271
Stoke on Trent
Not just me then, I was going to use standard downpipes to chop and mod first to see if it worked, then remake in stainless. Because its only going to be for a 998 I think it shouldnt be restrctive and retain some heat in the cast mani as well.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Guys where talking about using the metty turbo manifold and just having one lage diam pipe running 2 the side mount turbo.
I'd say go for it.
"Try to take over the world!"
