| Home > Help Needed / General Tech Chat > dash pot oil | |||||||
21 Posts Member #: 8731 Member |
29th May, 2011 at 04:29:52pm
what oil to use in the dash pot on a mg metro turbo carb |
29th May, 2011 at 04:41:45pm
proper SU damper oil. available from Berlen etc On 11th Feb, 2015 robert said:
29th May, 2011 at 05:24:28pm
If youre stuck or cba to get proper damper oil, you can run a 50:50 mix of 20w50 and 3in1 oil.
Edited by Carlzilla on 29th May, 2011. On 26th Jan, 2012 Tom Fenton said:
29th May, 2011 at 05:30:30pm
This is the proper stuff
1300 Posts Member #: 829 Post Whore essex |
29th May, 2011 at 09:01:38pm
i have used red x 1293 Turbo mini
150 Posts Member #: 8909 Advanced Member North Cornwall |
30th May, 2011 at 09:21:21am
I run castrol r in mine If in doubt... flat out! The words of a true legend |
30th May, 2011 at 09:31:21am
Use the stuff I linked to above, it's relatively cheep and it's what the carbs where designed to run on. On 11th Feb, 2015 robert said:
30th May, 2011 at 11:34:26am
sae 80 or 90 gear oil is the best we have done some tests on the rollers and get more consistant results over 20/50 as it gets thinner as it gets hotter thus causing slight lean spots when intial throttle is pressed, always looking for them bigger bunches of bannanas |
30th May, 2011 at 12:27:00pm
toyota type 4 atf fluid because i had it
Yes i moved to the darkside |
