| Home > Help Needed / General Tech Chat > clutch help and advice (again sorry) | |||||||
30th May, 2011 at 02:01:39pm
hey
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
30th May, 2011 at 05:26:09pm
is the clutch arm adjusted correctley on the stop bolt............... ie, its engaged all the time a tad ?
30th May, 2011 at 08:20:50pm
its had the rod extended atm, so carnt adjust. Culd this be the problem? And 107 at the wheels 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
30th May, 2011 at 08:52:24pm
Out of interest, why use the paddle plate ? |
30th May, 2011 at 09:35:05pm
30th May, 2011 at 09:36:25pm
duno y it double posted. Im only at 12psi and intend on raising it to 20+ 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Jun, 2011 at 07:24:18pm
anyone got any more thoughts? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Jun, 2011 at 07:47:59pm
if you have made the rod end which goes into the clutch slave cylinder long .....why have you done this ?
Edited by BENROSS on 2nd Jun, 2011.
2nd Jun, 2011 at 08:00:37pm
thanks benross, well the plunger and bearing were new about 700 miles ago so it should be ok.
2nd Jun, 2011 at 09:41:10pm
I had the same issue with mine. The cover kept bending the ball on the end of the arm. I got the Med arm and haven't any problem since. |
3rd Jun, 2011 at 10:12:17am
looks like the way forwards then. A stock arms never going to last against a grey is it? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
3rd Jun, 2011 at 10:35:09am
We're gonna give one a pop on a double grey so will have to let you know. If something is worth doing, it's worth doing half of. |
3rd Jun, 2011 at 07:15:20pm
Mines been working with a double grey for a couple of years now. |
3rd Jun, 2011 at 07:29:24pm
i havent had any problems with the standars arms the chepo ones from minispares
6th Jun, 2011 at 02:08:08pm
im going to try and adjust it up and see wat happens if not i think it will be a new plate 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
