| Home > Help Needed / General Tech Chat > Primary Gear Tolerance issue | |||||||
478 Posts Member #: 1962 Senior Member Lancaster |
30th May, 2011 at 04:09:01pm
Gents,
30th May, 2011 at 05:22:58pm
you need to linish a tad! off the back of the bronze thrust washer say using P 180 grit and finish off with 400 wet and dry to get the disired 6 thou
30th May, 2011 at 05:39:55pm
Cheers, but won't doing that open up the bigger gap on one side even more?
Edited by tomkidd on 30th May, 2011. |
30th May, 2011 at 06:32:53pm
for straight cuts I wouldnt be overly bothered,
30th May, 2011 at 07:10:52pm
Cheers, the C clip and backing washer are both brand new... |
30th May, 2011 at 07:31:43pm
They are not from minisport are they,
30th May, 2011 at 08:10:11pm
No... but they might from their same supplier? Have you heard of bad ones from Mini Sport Carl |
30th May, 2011 at 09:15:05pm
I might try a different 2nd hand C clip if I can find one and if that makes any difference unless anyone else some ideas? |
30th May, 2011 at 10:41:31pm
A lot of new parts are pants, basically does the C clip fit in the crank grooves without loads of play?
