Home > Beginners Tech > drum brake pipe thread size
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
hopefully get a quick answer, is the thread in front drum brakes the same as discs.
got a conversion to do tomorrow,
Yoshimura
Member #: 9204
Amsterdam...Edinburgh
as far as I konw this is 3/8 unf......but thats on my metro 4 pots.....
it's the same as my rear drums......
cheers Bas
jimmy
Member #: 829
essex
what was the disc brakes off mini or metro ?
1293 Turbo mini
you need a longer hose for drum to disk conversion
I thought it was the other way round?
The fitting on the drum is top (or is it bottom...) centre so you don't need much hose, but the calliper is at the edge of the disk so the hose has to travel further when the wheel is turned.
minispares note the drum brake hose as being longer than the disc brake one...............
The drum ones look shorter on egay...
wez
Member #: 9271
Stoke on Trent
Front drum brakes have the cylinders front and rear, not top and bottom so I cant see the length of the hose being massively different.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
this ones small........that ones far away................
Dougal, small......far away......
