| Home > Help Needed / General Tech Chat > light load misfire | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
31st May, 2011 at 02:06:05pm
Started suddenly on Saturday at Shakey.Misfire at idle and no load,cleared as soon as any load applied.Seemed like an inlet air leak.Tried resetting the regulator,couldn't get any flow through the jet.Took the float chamber valve out and found a load of debris,some red.Regulator diaphragm was breaking up.I'm told that the oil companies are putting ethanol in the fuel and this is attacking rubber in classic cars.Any thoughts? 'Where does the engine go?' |
