Home > General Chat > drive shafts with turbo power
jimmy
Member #: 829
essex
out of all the turbo uses we have on this form what drive shafts are you using i was going to use hardy spicer shafts ??
1293 Turbo mini
the standard ones a up to the job
jimmy
Member #: 829
essex
this what i have been using for years but i would like to go 1380 turbo
1293 Turbo mini
Cars with over 200 bananans (even up to 300 bananas) are still using pot joints.
Nothing wrong with the STD setup.
evolotion
Member #: 83
Glasgow, Scotland
apart from sheering at the outer cv inner circlip join :) but thats not a power issue, more of a hooligan wheelspin issue.
Denis O'Brien.
jimmy
Member #: 829
essex
so to over come this you use maxi CV ?
1293 Turbo mini
evolotion
Member #: 83
Glasgow, Scotland
no, you have custom shafts made without the offending groove. a maxi cv requires custom shafts anyways so may aswell stick with mini outers! easier to source.
Denis O'Brien.
jimmy
Member #: 829
essex
i no what you are saying
1293 Turbo mini
evolotion
Member #: 83
Glasgow, Scotland
was a common thing to use a cut n shut maxi/allegro? shaft back in the day i guess, as it'd be cheap n strong, but there a bit thin on the ground now. certainly it was common practice among the 16v boys, but supplies for the joints and donor shafts have all but dried up.
Denis O'Brien.
jimmy
Member #: 829
essex
you find a lot of the autograss boys buy it all up for spares
1293 Turbo mini
yes pot joins are ok as have been said, just to keep an eye on them for play every few years.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I've only heard of the occasional hub axle shearing....apart from that nothing
On 19th Jan, 2010 wil_h said:
I've broke a few shafts, will be ordering some ti ones later in the year.
jimmy
Member #: 829
essex
were ?
1293 Turbo mini
Force racing at a guess
