Home > For Sale > GT17 oil drain, ultralight flywheel
Ultralight flywheel - has had a brand new verto centre fitted by our esteemed swarf makee (Fast Carl). Used grey diaphragm (less than 2k miles), used friction plate (again less than 2k miles). plate and spring removed from the vans old engine and held well up to 18psi.
£100 + £7.50 postage (48 hour courier)
GT17 oildrain plate thingy. takes a 1/2" NPT fitting. - SOLD
Edited by apbellamy on 1st Jun, 2011.
just_jack
Member #: 2928
peterborough
Interested in the clutch/fly setup,
What does the verto style centre do to make any difference and ( I'll probably sound a real jebb end) is it a ring gear for a inertia starter
ThAnks
Jack
Jack Jones
The original flywheel taper was damaged, so Carl machined it for a removable verto centre. It just means that you need to use the verto bolt, lock tab and keyway washer which are inlcuded. It is the inertia ring gear. You may need to space the starter out by a couple of mm.
kenny2
Member #: 5362
wexford in ireland
hey could you measure the distance between the 2 fitting bolt holes on the oil drain for me please andy??
On 5th Jan, 2011 wolfie said:
The bolts are at 38mm centres.
The drain thingy is provisionally sold though.
oil drain sold.
just_jack
Member #: 2928
peterborough
Pm'd fly/clutch
Jack Jones
all sold
