| Home > Help Needed / General Tech Chat > coolant system? | ||||||
28th Mar, 2005 at 11:17:11pm
changing to a front mounted rad when i put my engine back in, just wondered where to run all the coolant hoses. On 20th Oct, 2015 Tom Fenton said:
29th Mar, 2005 at 12:33:55am
That's how miglias are plumbed in - albeit with a swirl pot and air bleed from the top of the 'stat housing...
29th Mar, 2005 at 12:52:52am
d'oh forgot about the header tank, yeah i'll be using the metro one though. the ultimate steady is already modded to fit the sandwich type stat housing as its what i had as standard on me cooper.
29th Mar, 2005 at 02:12:26am
The breather makes sure that air bubbles can escape into the expansion tank - ABOVE the water, where they are of little concern. Bubbles under the water level are what causes problems! On 17th Nov, 2014 Tom Fenton said:
29th Mar, 2005 at 08:43:07am
cool, forgot about that. so it just needs a small pipe teeing off the top hose then. the same kinda deal as the overflow pipe on a normal side rad yeah?
29th Mar, 2005 at 03:11:28pm
just look at a metro header tank and you'll see the pipe size - it's around 1/4" ID. Unlike the overflow, it's high pressure (well as high as your cooling system cap anyway) so use decent hose - not overflow stuff!!! On 17th Nov, 2014 Tom Fenton said:
29th Mar, 2005 at 06:04:38pm
