Home > Help Needed / General Tech Chat > venting the breathers
1310turbo
Member #: 41
i've seen this topic in another post before but i cant remember where, for anyone that knows, is it ok to vent the two breathers to air, and if so, what does the red (or grey) one way valves do and who is it ok not to use it?
cheers
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
don't use it!!
just vent to air.. but make sure your not leaving a vac leak but not plumbing the red thingy in :)
alex
AlexF
