| Home > Technical Chat > MPI Block questions? | |||||||
64 Posts Member #: 6668 Advanced Member |
5th Jun, 2011 at 06:48:53pm
Got an MPI block and am thinking of buying it. Couple of questions though. I notice that the block has two pressure relief valve openings. which one is used? I use a adjustable pressure fitting if it is the lower one it will not fit cause it's behind the starter. I like the fact that the entire block is beefier but the oil system redesign has me concerned. This is for an scca type full race engine and will get the four bolt main treatment a 8 counterweight crank and abused on the track only. Not ever seeing an mpi block up close before i don't know if they have inherent problems. Should i buy it? Aaron Racecar spelled backwards is Racecar |
5th Jun, 2011 at 07:46:43pm
The top hole os for an oil temp sensor. I use a standard relief valve nut drilled and tapped to take a mechanical oil temp gauge, its the same threads. This is the main oil feed from the pump to the filter.
5th Jun, 2011 at 07:53:36pm
There's also no hole for a mechanical fuel pump. There is a small hole for a cam sensor though, mine has been drilled and tapped and fitted with a little alu bung.
5th Jun, 2011 at 08:08:44pm
On 5th Jun, 2011 apbellamy said:
There's also no hole for a mechanical fuel pump. There is a small hole for a cam sensor though, mine has been drilled and tapped and fitted with a little alu bung. I'll be fitting an oil temp sensor like this one to the port on the front: http://www.merlinmotorsport.co.uk/p1373/TE...oduct_info.html I thought the standard relief cap was bit thin for drilling and tapping. The 5/8unf is a perfect fit. Drill a 14mm hole in the center and flatten the top off in the lathe. While its still in the chuck, mount the 5/8unf tap in the tail stock and tread it by turning the chuck by hand. I tell you this to make sure the threads are perfectly true to the flat top section where the copper washer or dowty seal seats or you are in danger of splitting the brass fitting, like what happened to me on the way to MITP 2009. I lost over 2 litres of oil before I started to wonder what the burning oil smell was. The fitting had split maybe 75% of the way around it! An ingenious fix was made 1.5 liters added, and I made it to MITP, where I then borrowed some oil from Jimster to top it off propperly. On 26th Oct, 2004 TurboDave16v said:
5th Jun, 2011 at 08:46:25pm
perfec. I'll do that then. Another justification for my lathe On 11th Feb, 2015 robert said:
7th Jun, 2011 at 11:56:55pm
Thanks Guy's, I think i will pass on the block for now. Aaron Racecar spelled backwards is Racecar |
8th Jun, 2011 at 07:24:01am
Where is the block and how much is it? I'm looking for a spare and would happily swap it for a standard A+ block On 11th Feb, 2015 robert said:
10th Jun, 2011 at 05:02:53am
Seattle Wa USA Racecar spelled backwards is Racecar |
10th Jun, 2011 at 07:55:31am
ah.... Getting one from Mr Sprocket now, so all is well. On 11th Feb, 2015 robert said:
13th Nov, 2011 at 04:36:58pm
There's also no hole for a mechanical fuel pump. There is a small hole for a cam sensor though, mine has been drilled and tapped and fitted with a little alu bung. I'll be fitting an oil temp sensor like this one to the port on the front: http://www.merlinmotorsport.co.uk/p1373/TE...oduct_info.html I thought the standard relief cap was bit thin for drilling and tapping. The 5/8unf is a perfect fit. Drill a 14mm hole in the center and flatten the top off in the lathe. While its still in the chuck, mount the 5/8unf tap in the tail stock and tread it by turning the chuck by hand. I tell you this to make sure the threads are perfectly true to the flat top section where the copper washer or dowty seal seats or you are in danger of splitting the brass fitting, like what happened to me on the way to MITP 2009. I lost over 2 litres of oil before I started to wonder what the burning oil smell was. The fitting had split maybe 75% of the way around it! An ingenious fix was made 1.5 liters added, and I made it to MITP, where I then borrowed some oil from Jimster to top it off propperly. Got round to doing this today. Ended up tapping it for a 3/8 BSP adaptor that came with my gauge. 15mm drill down the middle, but the concept is still the same it looks to work well. On 11th Feb, 2015 robert said:
