| Home > General Chat > Gauges | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
5th Jun, 2011 at 11:15:56pm
I'm going to be replacing the standard boggo 3 clock dash and adding new gauges for the turbo build - digital speedo & tacho, AFR, boost, accurate water temp, oil pressure, good petrol gauge too etc
5th Jun, 2011 at 11:30:26pm
Stack are good mate, that is what i have gone to now.
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
5th Jun, 2011 at 11:56:32pm
A little different to what you're after I think, but I too wanted to keep things simple;
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
6th Jun, 2011 at 11:42:23am
Mine-plank of mdf dash
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
6th Jun, 2011 at 12:48:12pm
smiths flight look gd, never seen them in a mini either 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
6th Jun, 2011 at 03:20:22pm
i'm a sucker for everything matching as well as keeping it simple, this is my dash
6th Jun, 2011 at 03:22:37pm
Thats looks awesome Simon!
Edited by John on 6th Jun, 2011. If something is worth doing, it's worth doing half of. |
6th Jun, 2011 at 03:32:09pm
The Koso is dead easy to wire in (pretty sure you can download a manual to look at before buying too), the only extra bit you need is the adaptor for the speedo cable which converts the rotational signal to an electronic one, I actually got mine free with the dash too.
6th Jun, 2011 at 03:41:54pm
Ah thats quite good then.
6th Jun, 2011 at 03:50:25pm
i'll have to dig out the manual on the temp readouts, but i think your right you have to press a button to switch between them.
Edited by Simon on 6th Jun, 2011. |
857 Posts Member #: 1778 Post Whore Northants |
6th Jun, 2011 at 04:03:59pm
With the Koso you can switch between various views, ie fuel level and water temp, oil temp and water temp, fuel level and oil temp. |
6th Jun, 2011 at 04:05:11pm
Excellent! I think my mind may be made up! If something is worth doing, it's worth doing half of. |
6th Jun, 2011 at 04:53:40pm
The only problem with the Koso is that it sounds like it's in the country illegally... On 11th Feb, 2015 robert said:
6th Jun, 2011 at 04:59:21pm
The views available are:
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
6th Jun, 2011 at 05:11:17pm
On 6th Jun, 2011 apbellamy said:
The only problem with the Koso is that it sounds like it's in the country illegally... hahahaha
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
6th Jun, 2011 at 06:25:35pm
the AEM gauges are brilliant, anyone with a UEGO will know how accurate they are, if a little too accurate, but their other gauges are just as good, spot on and very reliable. |
6th Jun, 2011 at 06:28:04pm
You can even use some AEM boost gauges as a map sensor up to 35psi boost !!! Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Jun, 2011 at 06:41:44pm
the one i have will regulate up to 29psi but you can get an external add-on sensor up to 75psi! |
6th Jun, 2011 at 07:00:00pm
some stuff on here
![]() 31 Posts Member #: 1961 Member Wellington New Zealand |
11th Jun, 2011 at 02:37:43am
The Autometer gauges might fit the bill, these are easier to get here in NZ than Smiths so was considering using these in my dash (don't know about UK) , Still have that old classic look.
Edited by NealfromNZ on 11th Jun, 2011. |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
11th Jun, 2011 at 08:11:14am
[X] nail here for new monitor |
16th Jun, 2011 at 03:03:14pm
Was looking for video's of Koso dashes on youtube and came across this! lol
