| Home > Help Needed / General Tech Chat > Verto to Pre-verto; clutch arm | |||||||
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
8th Jun, 2011 at 12:45:17pm
Howdy,
8th Jun, 2011 at 12:57:18pm
New brace bar.
8th Jun, 2011 at 01:06:49pm
you will never get enough lever action with the verto arm on a pre verto clutch. The clutch pedal would be rock hard!! On 26th Oct, 2004 TurboDave16v said:
8th Jun, 2011 at 01:22:13pm
An expensive solution - sleeve down the bore of the clutch master cylinder and have a custum made piston made to take an appropriate common size seal. With the right size bore the verto arm arm would mimic release bearing travel and foot pressure of the pre-verto.
8th Jun, 2011 at 01:29:58pm
The cable mounting thingy is quite big, not sure it would clear the servo and brace bar
8th Jun, 2011 at 01:34:08pm
New brace bar for me too. If something is worth doing, it's worth doing half of. |
8th Jun, 2011 at 01:37:44pm
On 8th Jun, 2011 Rod S said:
An expensive solution - sleeve down the bore of the clutch master cylinder and have a custum made piston made to take an appropriate common size seal. With the right size bore the verto arm arm would mimic release bearing travel and foot pressure of the pre-verto. Otherwise, something I thought about ages ago, it may be possible to completely modify the pedal box to take the cable of the (later) A series Metro vertos. Cable verto arm on Metros is a different angle yet again (so may still have clearance issues) but the cable operation could be so much simpler. ... or take Tom & John's advice; New brace bar! But cheers Rod for the enginnering solution
Thanks chaps. PS servo's gone now to make way for intercooler pipework, it's an old pic. |
here's the best I have
