Home > Help Needed / General Tech Chat > MPi oil filter options/opinions
Just looking at oil filters for the MPi block. Going by a search, Sprocket says the thread is 13/16 UNF. Looking for a decent filter with an anti drain back valve.
What are peoples opinion these?
http://cgi.ebay.co.uk/390289411042
Actually forget that link, they are too wide. only about 75mm on the face of the block
I'll sort you an OEM MG rover part number when i get home. I have cut open several oil filters from Fram, Halfords, Unipart and MG Rover. The MG rover filter is by far the better one. Unipart used to do a premium filter, cant find it anywhere now since I bought the last one from minispares. No magnet in them though, but are almost identical to the MG rover ones. Those ones have a slight waist in them which makes them easily identifiable. Common part for the K series engines too so plenty available.
perfect. Thanks
Do they have the anti drain back valve in them?
On 9th Jun, 2011 apbellamy said:
perfect. Thanks
Yes
I think my SA block uses these filters too. Same as the marina/spitfire.
Different thread
Monkeys! The thread is removable from teh block. I guess I could have an adaptor made up?
http://cgi.ebay.co.uk/NEW-GENUINE-MG-ROVER...=item4153518cba
Probibly
It's a bit of a PITA as the filters I have had so far don't have a valve in so when cracking the engine up it has to re-fill the filter before it gets oil pressure.
Hence the reason I would like a filter with a valve in.
Thanks Colin. They are just what I was after and not expensive. *smiley*
Just looked at my MPi block, I think you would struggle to get the threaded bit out. there's no hex section or shank to drip on.
Mine is just a bit of threaded tube with a lock nut on. It comes out easy peasy. I've taken it out a few times.
Get Carl to make you a new one then. Problem solved.
Soft jaw grips, job done
