| Home > Technical Chat > electronics | |||||||
29 Posts Member #: 2128 Member Wales |
11th Jun, 2011 at 11:40:40pm
Hi all, im a tad of a novice when it comes to electrics, ive managed to do all of the bulkhead conversion and get the engine in today with great supprise, but i am now stuck on the wiring from the dizzy to the coil and for the starter motor, as its not pre verto like my old 1 ltr engine
11th Jun, 2011 at 11:54:08pm
If you have the electronic distributor, you should have one red, and one black wire i think. Red goes to positive on the coil, black to negative. The type of starter youre using will also help, is the solenoid on the starter or a separate unit? On 26th Jan, 2012 Tom Fenton said:
11th Jun, 2011 at 11:58:25pm
Hi Carlzilla,
12th Jun, 2011 at 12:01:05am
Ah, inertia starter, in which case, you need a remote solenoid if you dont already have one yet. On 26th Jan, 2012 Tom Fenton said:
12th Jun, 2011 at 12:03:23am
oh nightmare, no i dont, is the wiring then the same on the inertia type with a romote solinoid? if so thats wikid and makes life easy. |
12th Jun, 2011 at 12:11:25am
No unfortunately, but its easy to swap over, you also need a flying lead from the starter to solenoid. The solenoid also requires a good earth, i mounted mine to the very front of my subframe so that i didnt have to move wiring. With my steel front i bolted it through the vertical bar that runs behind the grille. Ill take a photo tomorrow and label all the solenoid connections up for you. On 26th Jan, 2012 Tom Fenton said:
12th Jun, 2011 at 12:21:20am
If this works on my phone, looking at it as it is on the photo, top connections are all permanent lives and battery, middle left is coil 12v when cranking, middle right is from starter relay, the big spade terminal on this wire needs to be replaced with a normal sized one, don't get confused with the large terminal on the top post, and the bottom post is the starter flying lead. On 26th Jan, 2012 Tom Fenton said:
12th Jun, 2011 at 01:45:45pm
thats wikid thanks a lot for that, makes things a lot easier, i had a look at the dizzy this morning, it dosent seem to have any red or black wires, just one large wire with a conector in the middle that gos to a black box with "Ducellier" on it. Is this a modual of some kind? off that there is 3 wires
12th Jun, 2011 at 01:59:05pm
Sounds like you have a dizzy for a MK 1 Metro Turbo On 11th Feb, 2015 robert said:
12th Jun, 2011 at 02:01:26pm
Ahh, havent got much of a clue about that stuff mate, wouldnt like to guess it either, h&h ignitions maybe able to help if you ring them, they specialise in distributors and ignition systems On 26th Jan, 2012 Tom Fenton said:
12th Jun, 2011 at 02:03:43pm
ok well thanks a lot for all your help ill have a look if i can find i diagram someware. thanks again |
12th Jun, 2011 at 03:06:18pm
ive looked for a while on the net cant seem to find a mk1 metro turbo engine wiring diagram, anyone know how to wire up the ignition? |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
12th Jun, 2011 at 03:53:25pm
didnt realise ducellier made a turbo dizzy, whats the code on the side if you dont mind me asking? i had a metro turbo engine about 8 yrs ago which i sold on but i kept the dizzy as i didnt think it was a turbo one. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
12th Jun, 2011 at 05:22:08pm
sorry for delay was in the garage the code on the dizzy is 41832B which is made by lucas and the code on the modual (black box) is 521007C JZ Decellier Edited by minimad998 on 12th Jun, 2011. |
12th Jun, 2011 at 05:42:53pm
So the dizzy is lucas then, the one I kept is a ducellier dizzy so prob just a n/a dizzy then. Cheers anyway mate. one day boost will be mine!
12th Jun, 2011 at 06:02:17pm
Yh its Lucas, thats no problem |
12th Jun, 2011 at 08:26:40pm
has anyone done a mk1 metro turbo to mini conversion? or has anyone got a wiring diagram for a mk1 metro please, im supper stuck now :( |
12th Jun, 2011 at 09:12:55pm
Try the two wire format, White going to positive, and the black/white on the negative and see if anything happens, im sure i read somewhere that one pin isnt needed from somebody experimenting on what went where. On 26th Jan, 2012 Tom Fenton said:
12th Jun, 2011 at 09:39:32pm
ok ill have a wirl in the morning and see what happens thanks |
