| Home > Help Needed / General Tech Chat > engine Noise \"tut-tut\" on part throttle | |||||||
![]() 825 Posts Member #: 2208 Post Whore Essex |
12th Jun, 2011 at 12:51:55am
im getting a noise when driving in 3rd 4th gear, on part throttle or no throttle, and a small back fire every now and then when gunning it (out the back).
12th Jun, 2011 at 10:44:21am
any misfires under boost if all other departments are ok? .............is caused by the mixture too lean
12th Jun, 2011 at 11:01:00am
Paul,
12th Jun, 2011 at 11:18:50am
part throttle lean off? Yes i moved to the darkside |
12th Jun, 2011 at 11:36:10am
No part throttle lean of connected.
In the 13's at last!.. Just |
12th Jun, 2011 at 11:40:50am
PMSL!
On 12th Jun, 2011 theoneeyedlizard said:
Quit the beer for one weekend and you'll have enough cash to buy a wideband! On 28th Aug, 2011 Kean said:
12th Jun, 2011 at 12:54:49pm
An AEM lambda gauge is a must with a turbo engine
12th Jun, 2011 at 11:59:57pm
i thought i had det once, and it turned out to be a leak coming from the gasket out the side, ive also had a similar noise coming from the carb hitting the bulkhead when the engine vibrates. |
