| Home > Wanted > Small Diameter Pipe Bend | |||||||
12th Jun, 2011 at 01:01:54pm
I have two pipes I need to join together in my cooling system. One side is 1/2" I.D. from the bottom hose and the other side is 10mm I.D. water feed to the turbo. Normally this would be an easy job with a lathe but the pipes are almost parallel to each other so I need a 180deg bend in the joiner. Has anyone got (or can make) either a 10mm OD tight radius 180 deg bend that I can sleeve up to 1/2 on one side, or a 1/2" 180 deg bend that I can sleeve down to 10mm on one side?
12th Jun, 2011 at 01:21:14pm
Got these, both are 14-14mm o.d. The small one is Alu and the other is steel On 11th Feb, 2015 robert said:
12th Jun, 2011 at 01:25:43pm
Why can't I do attachments....
12th Jun, 2011 at 01:29:45pm
I'll have the steel one please. I can make something that will fit using that. Top Man.
12th Jun, 2011 at 01:55:56pm
Pm on the way On 11th Feb, 2015 robert said:
12th Jun, 2011 at 05:07:51pm
attaching pictures - The picture need to be lower case extention, not upper, even though its the same thing. IE .jpg instead of .JPG On 26th Oct, 2004 TurboDave16v said:
12th Jun, 2011 at 05:17:51pm
