Home > Technical Chat > turboing standerd 1275
minidan
Member #: 7107
essex
hi guys thinking of turboing my clubbys standerd 1275 just to give it a lil more poke dont want to run to much boost im gona run t2 on a mirage manifold just wonderd what else id need
thanks dan
andyuk1275
Member #: 9276
Darlington north east
pistons
On 12th Jun, 2011 andyuk1275 said:
pistons
I woud have thought he has pistons seeing as he says he has an engine and not a block
If just for low boost I'm sure std pistons will be OK so long as the rest of the setup is correct e.g. fuel and timing.
minidan
Member #: 7107
essex
thanks tom it will be set up once its up and running
I doubt you'll find a miniage manifold second hand
matty on here has been making batches of mirage style manifolds,
minidan
Member #: 7107
essex
is there a link for matty manifolds ??
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=385769
thinking about it I'm not sure he did a T2 one, but its worth a PM
An intercooler would always be of great benefit, youll also need a plenum chamber and some kind of blow off valve would also be beneficial, whether it be vent to atmousphere or recircularatory.
minidan
Member #: 7107
essex
thanks guys i alread have turbo inlet plenum and possibly a carb . once i get a few bits together ill start looking at intercoolers
Sam
Member #: 1686
Oxford
You will most certainly be better off with an OEM solotion if your on a budget rather then these crappy intercoolers off ebay.
Cosworth 2 and 4wd seem to be a good choice.
OMG Robert that's a big one
minidan
Member #: 7107
essex
ive just brought a mk3 mondeo tdci intercooler seems a good size
Yeah, ive got a cosworth 4wd intercooler to fit, and even behind a clubby fg front its fooking huge. If its a roundnose, something small like an audi tt intercooler is best at the front of the engine bay catching as much airflow as poss
