| Home > General Chat > Cranking Advance | |||||||
12th Jun, 2011 at 05:50:11pm
Chaps what cranking advance do you use on your MJLJ?
12th Jun, 2011 at 06:08:14pm
some
12th Jun, 2011 at 06:41:05pm
So its better to have more advance? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Jun, 2011 at 06:46:49pm
5 degrees is normal for the injection Minis. 10 degrees works. any more and you might start getting to the point where the engine kicks back while cranking.
12th Jun, 2011 at 06:48:51pm
somtimes with too much ign advance at cranking the engine can kick back or be hard to crank, so a lower cranking figure can help,
12th Jun, 2011 at 06:54:08pm
Thanks for this Joe, so its kind of like a simple anti stall? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Jun, 2011 at 07:53:57pm
It is a very simple form of idle speed control Mike, adding a control to add air by a idle control bypass valve is more effective, but the advance trick is plenty good enough for what we need.
12th Jun, 2011 at 08:06:23pm
Ahh thanks for the input fellas im also going to be running the aux input from an aem wideband.
