Home > Non-Mini Discussion > Non Mini related (Compression ratio)
blister
Member #: 2590
Croydon
If a engine has got a CR of 10.7:1 N/A and you are after running a supercharger how do you work out a suitable CR
does it vary depending on engine?
How much boost and what type of SC.
Always a bit of a finger in the air thing.
blister
Member #: 2590
Croydon
eaton m45 and standard pulley size on charger
bottom pulley size is 130MM and i am after running 7psi through a larger IC which will be in direct air flow
Edited by blister on 13th Jun, 2011.
wez
Member #: 9271
Stoke on Trent
What engine is it though? I know on the yaris 1l 16v engine, they do a turbo kit to run 7psi on the standard cr of 10:1.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
blister
Member #: 2590
Croydon
Vw lupo engine
got two lupos now and whilst i am using one the other is off the road being tarted up
If you want the complicated answer, it depends on intake air temperature and dynamic compression ratio. Intake air temperature will depend on the ambient temperature, boost pressure and supercharger and intercooler efficiency. Boost pressure will depend on the pulley ratios, engine size and blower capacity.
Just use 9:1.
