Home > Help Needed / General Tech Chat > Small 50 amp alternators
NickG
Member #: 7912
Australia oi oi oi!
Are they enough power to run
Megajolt or efi?
Small amp 10 inch amp sub and head unit and aircon when ever it is used not much...
Thinking have a 60 or 65 amp rover one and it's huge thinking of buying one a small one.
Any photos?
I run a 45 amp one on mine with EFI and its fine,
NickG
Member #: 7912
Australia oi oi oi!
Excellent Joe! There are a few around.
Was thinking of buying this?
http://www.ebay.com.au/itm/ALTERNATOR-UNIV...e#ht_2668wt_897
thats the sty;e I'm using, but not so shiny!
thats not a bad price either, this side of the pond anyway.
I've got a 55amp N.D. for mine, will be running ecu etc. Only bought that as it was competitivly priced.
NickG
Member #: 7912
Australia oi oi oi!
Apbellamy can you link me to the 55amp one you bought? Or a part number.
I think those shiny ones may be race alternators no good for a everyday mini.
Will still ring him and check
Mine is the same as the one you linked to, but not shiney. Had it a couple of years so haen't got a link.
will dig the part numbers out later if I remember
NickG
Member #: 7912
Australia oi oi oi!
Ok thanks mate, part number would be great I can venture up the road and grab one if the 50 amp is no good
http://www.ebay.com.au/itm/Alternator-Kubo...#ht_4875wt_1002
Another I found
http://cgi.ebay.co.uk/H073-5V-55Amp-Denso-...6c#ht_850wt_922
Edited by NickG on 16th Jun, 2011.
Part number on mine is:
119254-77200
I'm sure they are all pretty much the same though. Just check what connector they use as the funny round ones are not cheep
NickG
Member #: 7912
Australia oi oi oi!
You are a legend mate!! *happy*
From measurements I found that just to run a mini (with MS, FI fuel pump and a few dials and lighs on the dash) was around 4 amps.
I should re-do the measurement with injectors etc and see the differance.
If you added up all your lights, heater fan etc, it may get to 50 amps, but it would be in extreme circumstances.
AWDmoke
Member #: 713
Western Australia
Nick, you should standardise.
Just get a second hand Nippon Denso alternator off a Swift the same as in your other car.
Then you'll be able to swap them if you ever have a problem.
On 24th Dec, 2008 Nic said:
NickG
Member #: 7912
Australia oi oi oi!
i did alot of research today.. Mucking around instead of working..
my findings are, going through books & books!
all the smallest alternators, that you all want to run are all from Kubota mini diggers, they are all cheap as hell from USA new.
search Kubota, mini diggers Alternator world wide, via ebay, some come uprated factory, all 12v, all nippon denso and un-wound, so will work normally, charge normally, not like a race alternators.
they are very small from 30 amps 45amp the bigger type ones come in a 60amp but still very small.
perfect for retro fitting!!
i have listed the ebay sellers, so in future if people search? instead of dead ebay links! search the shop & you will find!
55amp unit
ebay seller rareelectrical cheapest so far
http://www.ebay.com.au/itm/NEW-ALTERNATOR-...c#ht_2706wt_907
tiny 30amp unit also comes in 40 & 45amp
ebay seller caltric ** cheapest seller*
http://www.ebay.com.au/itm/Alternator-Kubo...#ht_2554wt_1141
http://www.ebay.com.au/itm/Alternator-Kubo...#ht_3708wt_1141
below the tiny 40amp unit with video
ebay seller crank-n-charge
http://youtu.be/Ln4GvCKvpo4
http://www.ebay.com.au/itm/NEW-Alternator-...a#ht_5912wt_933
60amp unit ebay seller budda06320
http://www.ebay.com.au/itm/NEW-KUBOTA-TRAC...9#ht_4568wt_907
if you want to go the full hog go tiny 85amp nippon denso alternators.
http://www.gzmotorsports.com/racing-alternators.html
i think i will buy this one,
ebay seller info caltric now sold out, price has been jacked up.
http://www.ebay.com.au/itm/Alternator-Kubo...#ht_2272wt_1141
55amp
AWDMOKE, yes i have a spare, just looking for something new & cheap it's $300au up the road & the same thing in Usa to my door is $140 lol via ebay!
Edited by NickG on 18th Jun, 2011.
NickG
Member #: 7912
Australia oi oi oi!
55amp
moke123
Member #: 4584
Perth, Australia
how much effort is it to mount these to the standard mounting points on the block?
does anyone have photos of the brackets they've used?
