Home > Help Needed / General Tech Chat > Running Problem
ERA ANT
Member #: 4179
Cumbria
Hello all :) i have abit of a problem *oh well*. I have a Metro Turbo and its got a weird fault! I can be driving along and the wideband will go really lean and the car will run fine and then it works fine the next min but some times it goes lean and it missfires. So i removed the carb and gave it a serious looking at *tongue* and it look ok. So i refitted the carb and now it wont even run but it ran when i sprayed brake cleaner into the inlet and it ran for a few seconds then cut out so it wasnt getting fuel. So i tried the spare carb on that i have and it wudnt run either till i sprayed brake cleaner again. Then it ran for about 5 mins then cut out agen and now it wont run again. I have checked the fuel filter and it flows fuel fine etc. Any ideas???????
Do it right the first time and make it mint!!!!!!
first to look at is
sticking float valve
