| Home > Help Needed / General Tech Chat > plenum question | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
19th Jun, 2011 at 06:26:25pm
hi guys,
19th Jun, 2011 at 06:31:21pm
Mine had some rubbery gaskets arround the bolt heads i dont belive this was stock and there should be a gasket between the carb and plenium-be-dum-erus Drives
19th Jun, 2011 at 06:37:12pm
19th Jun, 2011 at 06:45:02pm
the gasket between plenum and carb should prevent all leakage Yes i moved to the darkside |
19th Jun, 2011 at 06:49:58pm
Throtel will be open on boost when its not the excess boost will be relised through the bov (recomended to fit on for longer life of the turbo and carb) Drives
19th Jun, 2011 at 07:12:06pm
great.. thanks guys.
19th Jun, 2011 at 08:04:00pm
If you look inside the plenum, you can see the bolts go through tube or the plenum body. The holes are not open to boost so you won't get any leaks. On 11th Feb, 2015 robert said:
19th Jun, 2011 at 09:59:50pm
oh i see...
