Home > Wanted > gearbox bolts, turbo elbow bolt and circlip for actuator arm
bennyy
Member #: 9037
Doncaster, yorkshire
I'm after the bolts and nuts that hold the gearbox to the block, the smallest of the turbo elbow bolts, and the circlip that holds the actuator arm on.
Anybody fancy sticking them in the post for a bit of beer money?
Cheers.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
bennyy
Member #: 9037
Or does anybody know the thread size so I can get some new ones?
http://shop.ebay.co.uk/madminidesigns
Dave should be able to sell you the gearbox bolts. Just send him a message and I'm sure he'll list you some *smiley*
http://cgi.ebay.co.uk/Garrett-T3-T34-T38-T...e-/320669427815
3 x actuator circlips (for when you ping one off)
Dunno about the turbo elbow bolt unfortunately.
bennyy
Member #: 9037
Yes just seen the circlips this morning ordered some and ok ill send him a message when I get in :) can't do ebay messages on my phone :(
It's turbodave16v on here if you want to pm him?
I'll measure the turbo bolts in a bit. they are M8 from memory
bennyy
Member #: 9037
Yeah ill drop him a pm, and thankyou andy, its the smaller of the 3 I need
This may help you mate.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=390175
Typically I can't find the short one either. They are M8 though. I would measure the thickness of the bit the bolt goes through and into and order one to suite. Don't forget the lock tab
Dr. jinG
Member #: 368
Roseville, CA (USA)
apbellamy, are you sure of that? Metric on a Mini? I understood the bolts to be 1/4-24. I also understand that drilling and re-tapping to 5/16-24 is a much better way to go, if you have it apart and can do it.
1967 Cooper 's' Turbo build @ www.drjing.com
They are metric as they where put there by Garrett rather than Austin. Had to have one drilled out of one of our turbos...
The bolts that hold the block to the Gbox are 1/4 get some high tensile cap head bolts.
bennyy
Member #: 9037
Cheers, any idea on the length? I seem to remember 1'' - 1 1/2'' but havnt seen them since I took my box off about 2-3 months ago lol
Here you go. TD has listed some *smiley*
http://cgi.ebay.co.uk/Classic-Mini-Engine-...s-/160607225808
bennyy
Member #: 9037
ta john, got some on order :)
