Home > Help Needed / General Tech Chat > engine spec questions
ed-moss
Member #: 7192
bradford
here is my proposed engine spec.
please let me know if im making any obvious goofs, or anything i should add. thanks
1275 std metro turbo block, std turbo rods and pistons, with total seal rings.
arp rod bolts, centre main strap thingy
turbo worked head, 35.6 rimflo inlets, 29.5 exhausts
uprated valve springs, lightwieght tops ect, cant remember spring rate.
bronze valve guides
uprated solid spaced rockers
arp 9 stud head kit.
bk450 head gasket
std turbo gearbox with xpin evo diff and centre oil pickup
sc drops (minispares)
avonbar stage2 billet cam (not yet bought)
lightweight cam followers, turbo oil pump
t3 turbo
venier duplex timing set
cant think of anything else ive bought yet!
any ideas what i should do different?
ask me tomorrow for discount
ed-moss
Member #: 7192
bradford
ohh mega intercooler, and megajolt. cant remember what megajolt it is, but its a new style one!
What crown wheel and pinion will you run?
Our metro van had a similar spec'd engine, but with an MG metro Cam. Mate about 150 bhp with 14-15psi, running a T3. We broke the first motion roller bearing in the gear box, but otherwise it went well.
What compression ratio will you use?
DaveVader
Member #: 9075
Peterborough
If you need an intercooler then I have an RS intercooler or a Sierra 4x4 intercooler which will both be up for sale soon.
ed-moss
Member #: 7192
bradford
thanks, but i have all my parts already.
as for c/r, ive no idea!
you need to work that out or chances are you'll melt it all on your first outing....
ed-moss
Member #: 7192
bradford
if i did work it out, what help would this give me as far as my spec is concerned? thanks
Tell's you how much boost you can safely run, how much ignition advance etc etc
