Home > Wanted > Viton tiped needle thingy
Has anyone got one lying around or where to get one??
im stil trying to solve my fooooooooooooookin fuel problems when i get chance.
rick
tadge44
Member #: 2500
Buckinghamshire
Burlen Fuel Systems or Avonbar
something to note , in my experience , if you go to to big a hole ,then the viton tips can get stuck ,and create all sorts of fuel deivery probs . i used a high flow needle from avonbar ,it leaked ,and i could blow through it ,so they sent another ,...it leaked ,and in the end used a turbo rebuild kit one ,which turned out to bigger than the high flow ones ,and was not viton aficr.
Are we talking needle valve? or main jet?
valve wil
In that case, I'll have a look in my box of carb bits. Not sure what sizes I have , but all the ones I have are the same size and likely turbo.
They won't be new, but none leaked when in use.
Star Mag
Member #: 375
Leicestershire
My last turbo carb rebuild kit came with one in it. Seems to seal with the valve drilled slightly.
tadge44
Member #: 2500
Buckinghamshire
How big did you drill it ?
I went for 0.125" as standard is 0.090"
I didnt even realise you guys drilled the hole.?
Well i had one in the rebuild kit but didnt put it in.
Star Mag
Member #: 375
Leicestershire
To be honest I can't remember! I do remember they aren't the same size all the way through. I drilled it all slighty larger and made it the same size all the way through if that makes sense.
Not very accurate way of doing it but it sorted my problem at the time!
drilling the hole can cause problems if the edge isnt perfect. Although the viton tipped valves will stand more chance of sealing than a plain brass.
Although you can try and lap a brass one in with some valve grinding paste ( and clean thoroughly afterwards )
I think the std valve can be taken to around 2.8mm at most before the valve falls into the hole.
A lot of Weber ones are around 3.0mm
