| Home > Help Needed / General Tech Chat > Alternator / Overrun Issues | |||||||
22nd Jun, 2011 at 10:10:04pm
I've re-wired my Megasquirt so that it is now fed by an ignition switched relay. The switched supply is the old coil supply on the same switched feed from the ignition barrel as the alternator energise supply (i.e the one for the ignition light). The MS is then fed with a supply directly from the battery through the switched relay.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
22nd Jun, 2011 at 10:19:02pm
Prob not relivant but when my alternator went on my old astra sport it kept the whole circuit perminatly live till the battery went flat. Could be something similar?? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
22nd Jun, 2011 at 10:31:41pm
This is interesting. Especially as my car is a '77. Might give it a go.
22nd Jun, 2011 at 10:32:57pm
Is it back feeding an earth through the relay coil? On 7th Nov, 2011 apbellamy said:
22nd Jun, 2011 at 10:35:32pm
Like I said... You might need a relay with a diode in, or fit a diode so you don't get a feed back into the circuit when off On 7th Nov, 2011 apbellamy said:
22nd Jun, 2011 at 10:49:33pm
This is happening to us with the van! If something is worth doing, it's worth doing half of. |
23rd Jun, 2011 at 08:00:23am
I'm off to buy a diode later Fastest 998 mini in the world? 13.05 1/4 mile 106mph
23rd Jun, 2011 at 08:18:48am
Keep us updated. The van has the same symtoms. We have to pull the relay to stop it sometimes. It's also been killing batteries on a regular basis... On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 08:37:26am
I'll buy 2 diodes and if it works I'll bob one in the post for you.
23rd Jun, 2011 at 09:49:26am
Good plan. I'll swap you for a push rod at Avon. On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 09:59:57am
This happens to the 998 ti ocaissionally.
23rd Jun, 2011 at 11:00:42am
It's a deal.
On 23rd Jun, 2011 apbellamy said:
Good plan. I'll swap you for a push rod at Avon. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
23rd Jun, 2011 at 11:15:42am
