| Home > Help Needed / General Tech Chat > Have I killed it | |||||||
25th Jun, 2011 at 06:36:50pm
Ok then the saga goes on Edited by madmk1 on 25th Jun, 2011. I have started posting on Instagram also my name on there is turbomk1golf
25th Jun, 2011 at 06:42:03pm
Hmm this is a strange one? You had a plug out? If something is worth doing, it's worth doing half of. |
25th Jun, 2011 at 06:53:32pm
No not yet, I have not even looked at it.
25th Jun, 2011 at 06:59:34pm
Hum...
25th Jun, 2011 at 07:05:53pm
timing belt/chain? hope not for obvious reasons! turbo 16v k-series 11.9@118.9 :)
25th Jun, 2011 at 07:13:39pm
Does the oil pressure gauge have a capillary to the gauge, or an electric sender? If it is an electric sender could you have lost a common feed to the ignition and the gauge? |
25th Jun, 2011 at 10:03:26pm
On 25th Jun, 2011 evolotion said:
timing belt/chain? hope not for obvious reasons! Its on a chain On 25th Jun, 2011 Joe C said:
Hum... pop the oil filler off and check the rockers still move when you spin it over. I see this would show it the timing chain if broke, could/would it snap then? I have started posting on Instagram also my name on there is turbomk1golf
25th Jun, 2011 at 10:05:54pm
As per your sig, nothing is impossible....
25th Jun, 2011 at 10:09:18pm
Looks like i will start with this then.
26th Jun, 2011 at 10:02:47am
Not if the valves are bent! On 5th Sep, 2011 Vegard said:
26th Jun, 2011 at 11:28:01am
and the cam and rods have collided... :( On 28th Aug, 2011 Kean said:
26th Jun, 2011 at 05:51:14pm
Man you have worse luck than me... Pisser got to be one of my fav cars I run a supercharger and I don't care the TB is on the wrong side.
26th Jun, 2011 at 08:28:31pm
Easy to find out. Take the oil filler cap off, take the plugs out, jack one front wheel up, stick it first gear and turn the wheel while watching the rockers. 10 minute job at the most. At least it will put your mind at rest as to whether the engines catastrophic or not On 26th Oct, 2004 TurboDave16v said:
26th Jun, 2011 at 08:42:52pm
Right then I went out today to do some fault finding. I checked I had spark and rocker movement, and spent another 30 mins pissing about looking at it. I then had a brain wave and checked the fuelling and guess what! the tank was empty but the gauge was still saying 1/4 tank so I think the sender is f***ed. So I filled it up and its running nicely again so panic over.
26th Jun, 2011 at 08:43:58pm
26th Jun, 2011 at 08:47:57pm
I just feel a bit of a Dick now :$ I have started posting on Instagram also my name on there is turbomk1golf
26th Jun, 2011 at 08:48:42pm
On 26th Jun, 2011 madmk1 said:
I just feel a bit of a Dick now :$ Well at least its not bust! On 7th Oct, 2010 5haneJ said:
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
26th Jun, 2011 at 09:04:27pm
Happy days! one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
26th Jun, 2011 at 09:05:24pm
Well im glad for you mate. |
26th Jun, 2011 at 09:06:19pm
I'm pretty sure we've all done that. I have. Spent 20 minutes tearing my hair out wondering why the car stopped and wouldn't then go. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Jun, 2011 at 09:16:26pm
Right then I went out today to do some fault finding. I checked I had spark and rocker movement, and spent another 30 mins pissing about looking at it. I then had a brain wave and checked the fuelling and guess what! the tank was empty but the gauge was still saying 1/4 tank so I think the sender is f***ed. So I filled it up and its running nicely again so panic over. I ran out of fuel in my old Schitroen Xrara, my own fault, drove straight past the service station, but, I was on my way back there since I knew I was running on vapour. The engine died right at the end of the A500/M6 j15, right on the roundabout. My own fault. However, no fucker stopped to help me push the car out of the way, only shouted abuse about what a dick I was for causing the very large tail back at rush hour. Anyway. 2 weeks later driving in the outside lane on the M6 North, the engine dies just as I was approaching J20/ M56 (6 miles from home), I managed to coast through the inside two lanes with the hazards on full blink. Fuel gauge siad 1/4 tank. Refused to start. AA man added 5 litres of derv and hey presto it starts. Knowing for sure I had 1/4 tank left, the AA man followed me to the service station where I refilled his jerry and I filled the tank. Yep, I only managed to get 3/4 of a tank in there. The fuel sender was faulty, and was shutting down the pump, thinking it was going to run dry. I was really made to feel like a dick when the boss got wind that I had the AA out twice for running out of fuel. don't know why I am telling you this, only perhaps to make you realise that shit happens either by our own doing or by parts that fail to show the real situation. D On 26th Oct, 2004 TurboDave16v said:
26th Jun, 2011 at 09:22:29pm
In my defence the tank is new to me. I have started posting on Instagram also my name on there is turbomk1golf
26th Jun, 2011 at 09:23:21pm
I found out that the estimated miles to go in my BMW is as accurate as you would expect ze germans to be. Got to 0 and stopped 100 yards later. Luckily 5 feet from the fuel pump in a garage. |
26th Jun, 2011 at 09:37:26pm
Great news I would rather be a dick than have to rebuild the engine. I run a supercharger and I don't care the TB is on the wrong side.
26th Jun, 2011 at 09:42:38pm
Easiest fix ever!! Good news.
, Right I have just been out in the car and as I was driving the car lost oil pressure and cut out! So when I went to restart it I had No spark and No oil pressure on the key but had a bit of smoke form the exhaust (that has never happened before). It is not leaking at all.
