| Home > General Chat > MPI help | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
25th Jun, 2011 at 07:32:12pm
I've been trying to help a mate out with his mpi, but having no luck!
25th Jun, 2011 at 09:50:45pm
The idle air control valves are notorious for breaking. The valve body usually cracks where the large pipe attaches that runs from the throttle body On 26th Oct, 2004 TurboDave16v said:
26th Jun, 2011 at 09:17:06am
Would that cause it not to start then? Or should i say would it cause the fuel pump to not operate, it does not even kick in for a couple of seconds when the ignition is turned on. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
388 Posts Member #: 442 Senior Member Manchester |
26th Jun, 2011 at 04:22:42pm
The fuel cut off switch hasnt tripped has it? |
27th Jun, 2011 at 06:56:24pm
tried that! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
27th Jun, 2011 at 06:56:50pm
28th Jun, 2011 at 09:06:48am
Is the imobiliser switching off properly? Red light going out etc?
28th Jun, 2011 at 11:01:13pm
Check the 13 way loom connector pins for scorching. There are two of these connectors. One on the bulkhead by the inertia switch and the the other under the dash on the passenger side right up in the corner of the inner wing/ parcel shelf area. On 26th Oct, 2004 TurboDave16v said:
5th Jul, 2011 at 07:25:33pm
the immobiliser is switching off as it should and there is no power at the pump...so will try sprockets advice and see how that goes.. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
