Home > Help Needed / General Tech Chat > Tidy Engine Bays
carts60
Member #: 9335
Bromley, SE London
I'v been reading lots of build threads trying to get ideas and general help for when I have rebuilt my engine and am ready to swap out the old N/A 1275.
What gets me though is how neat some of the engine bays are!
As factory my engine bay has wires here the and everywhere running to and from god knows where as well as the wiper motor, washer bottle, servo etc taking up a load of space and looking generally unsightly.
So the question is: how on earth do you do it and where does everything end up going?
Wiring always makes an engine look shit, ive ran all mine along the bottom of the engine.
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
I'm removing my brake servo & rerouting my fuse box to the dashboard thus running the wires between the dash & the bulkhead.
But the washer bottle can be relocated in the boot.
Timinichelsea
Member #: 479
It takes a lot of doing to get them hidden.
I've got different master cylinders, moved the wiper motor, custom wiring loom which runs under the engine.
I have seen washer bottles and wiper motors moved inside the cabin, i want to try and have as much wireing as possible hidden out of the way, with a steel front personally its easyer to hide wireing. I would love mine to end up looking like the engine isnt wired up looks proper cool imo
johnK
Member #: 690
Norfolk
on my old yukon grey 7 port car I made the loom come down the wheel arches along the inner wing, both sides then into the bay from underneath. This kept thefront very uncluttered.Washer bottle in boot, fuse box behind dash etc, also a power distrubution post behind the dash as well. pre engaged starter helps as there is no extra solenoid etc. - it takes time but is worthwhile. Goldies engine bay is that full of stuff a few extra wires don't make any difference! but on a sparse engine bay its a good look
If Carling made Mini engines
eden7842
Member #: 8852
leicestershire
sometimes its problibly faster to rip the lot out and start again when trying to hide wires, but it depends on how far you want to go
I've stopped caring how the engine bay looks now!
carts60
Member #: 9335
Bromley, SE London
Thats what I was thinking. I'll definitely be taking all available wires and trying to re-route them whilst the engines out.
The car is going to be more 'function' than 'form' so im not going to go overboard, but i'll try to get it as tidy as possible.
It doesn't help that i'll also be keeping the servo. Re-routing the washer bottle also seems hassle given the time i'll be trying to complete the build in (and the fact it works perfectly well where it is at the moment. May however try fitting it under the drivers side wing with an access funnel cut into the inner wing to see how much is left and for topping up.
We'll see how it goes.
pot_dan
Member #: 326
bradford, west yorks
I can't get pics hosted of mine yet but I have hidden mine in the inner wing then they go into the slam panel to the other side the only wires you can really see is the coil wires but megajolt should be fitted by next year.
