| Home > Help Needed / General Tech Chat > Subaru Td04L vs Saab TD04HL-15T | |||||||
27th Jun, 2011 at 10:21:25pm
I have been looking for a while for a saab Td04 and have not found one for sensible money either on ebay or at any breakers.
Edited by minimole23 on 27th Jun, 2011. On 7th Oct, 2010 5haneJ said:
27th Jun, 2011 at 10:56:55pm
Well after a little research there appears to be quite a few variations of the Td04 fitted to various subarus - I'll keep searching. On 7th Oct, 2010 5haneJ said:
27th Jun, 2011 at 11:18:07pm
IMO you want to be looking for a td04 or a td04L, the tdo4H and HL have a larger turbine which i doubt will boost till quite late.
Edited by Joe C on 27th Jun, 2011. On 28th Aug, 2011 Kean said:
29th Jun, 2011 at 10:22:36pm
Pretty sure all TD04's fitted to Subarus here are the same. And they used the things from 1995 or so right through til about 2006 !
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
28th May, 2013 at 04:15:17pm
has anyone tried one of theses?
16V project underway |
28th May, 2013 at 04:22:32pm
Why not a ball bearing turbo off of an iveco van? Good on small cc engines (eg 1275+)and good for over 200bhp. Just have no idea on maps or style, but it's on the modern iiveco's and some merc sprinters.
Edited by Paul R on 28th May, 2013. Drives
28th May, 2013 at 04:23:29pm
good on small bores? really?
28th May, 2013 at 07:05:46pm
I bought one then sold it again, deciding the GT20 was a much better selection! On 7th Oct, 2010 5haneJ said:
65 Posts Member #: 9646 Advanced Member Bristol England |
14th Oct, 2014 at 06:53:47pm
Hi guys, been reading the thread,I'm running a 1275 16v k headed with a r5 t2 megasquirted, works very well, was at Combe this year kept a redtop on throttle bodies and a Elise powered car at bay. Don't think I saw any of you guys. Any way I've pushed the max out of the T2 about 16/17 psi, it's just creating a lot of heat and runs out of steam by 5.500. I'm sure the engine will take more boost so need another turbo. I've got the chance to get a saab td04HL15-5 turbo, has anyone ever tryed one with a similar set up to mine? What results do you think I should expect. |
14th Oct, 2014 at 08:27:07pm
i would opt for the gt series 1752 or 2056 for large power outputs, the first one would be my option
14th Oct, 2014 at 08:40:46pm
The only reason I thought it would be ok is that a lot of the Toyota Starlet lads use td04's as an upgrade, those are 1300 twin cams, I know it's a modern engine probably very strong and well balanced compared to the old A series, but there quoting outputs of 300 bananas using then. |
14th Oct, 2014 at 10:32:12pm
I have a TD04-11B (or could be 11G) which will be up and running in a month or 2. If you search just for TD04 you'll see lots of variants, 11,13,14,16,19... quite a broad range of specs and sizes despite the similar name.
Edited by PhilR on 14th Oct, 2014. |
18th Jan, 2015 at 09:13:39pm
Hi guys, just a revisit to the td04 debate. I've done lots of googling and comp map reading the td04-13t seems to be a good choice for a k16v 1275. I've looked through all the td04 threads via 'search' which is interesting reading, although I can't find anywhere, here or Google, a list that 'decodes' the type numbers. ie what does the 'l' mean in Td04l what does the 't' mean in -13t. Any ideas? |
