Home > Help Needed / General Tech Chat > Cam Timing
jonb_5
Member #: 3193
Torbay, Devon
I will be setting my cam up at 106 degrees but I have a new chain set.
I will need to allow for stretch which I have read is 1-2 degrees.
Can someone please confirm I would need to time the cam in at 104 degrees and not 108?
Thanks
Jon
steve1275
Member #: 951
Bromsgrove
Correct.
'Where does the engine go?'
bennyy
Member #: 9037
Doncaster, yorkshire
Spot on my freind.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
jonb_5
Member #: 3193
Torbay, Devon
I have set-up my dti through the spark plug hole and rotating clockwise there does not seem to be any dwell on TDC.
It just starts to move straight back down again. The scale on the dti is .0005", would this be why?
I was expecting a dwell and to have to take a reading a couple of degrees before and after.
Also do I need to removed the rockers and set off the top of the push rod or can I do it from the top of the rockers?
Many Thanks
Jon
you can do it from the rockers but its a pain remove the rockers and use the push rod
