Home > Help Needed / General Tech Chat > Design help required
advantage998
Member #: 1840
Kings Lynn, Norfolk
I am going to get some aluminium laser cut to mount a cinqucento radiator and fan.
I have the basic profile and fan location but i've tried numerous different ideas to remove material from the left hand side to allow maximum airflow.
I seem to remember somebody had made similar for a radiator mount may have been andywaller? But the pics have vanished.
Is anyone more artisctic than me and have any ideas on what would look good?
I would say straight horizontal fins.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Hmm its close but i'm not 100% sure
quinton
Member #: 1911
how thick are you planning on going?
advantage998
Member #: 1840
Kings Lynn, Norfolk
3mm should be sufficient. It will be bent at the dotted line and will be attached to the suframe with rubber mounts. And then a suppport from the top of the rad to the body.
That is going to stop a lot of air getting through the radiator
pickmeup
Member #: 1200
i would remove as much of the material as possbile, if its only a mount and its 3mm thick you only need to have it around 10mm in width offset from your outside edge.
Ben H
Member #: 184
Melton Mowbray, Pie Country
You need to consider the surface area of the rad. Basically take the total area of the rad, then subtract the amount of metal (you will have to guess this). Then you are left with the air in the rad (I hope you are following this). You don'e need any more ait to or from the rad. What you will find is that it is much smaller than you think.
A lot of OEM fans create a route from the rear of the rad to force it through the fans, thus making the fan more efficient and not effecting the forced air performance.
I have the same rad and am planning on just a number plate sized opening. I need to work it out properly yet though.
http://www.twin-turbo.co.uk
That looks confusing.
You are building a shroud of some sort to allow the fan to draw or blow air through the radiator core. Then you are cutting lots of holes to massively decrease the efficiency of any fan ?
Is this in front, or behind ? pusher or puller ?
On an OEM setup where they open up holes in a shroud, they always either have soft rubber flaps to allow airflow in one direction only, or a mechanical system to open/close flaps. So that the fan doesnt simply blow air that can escape going through the core.
How close will this thing be to the core itself ?
advantage998
Member #: 1840
Kings Lynn, Norfolk
Basically the 3 lugs are the mounting points on the rad. The fan hole is positioned where it needs to be and the rest of the material i can lose.
This will be behind the rad, and the fan is a pull fan. It sits approx 5mm from the core.
Johnny
Member #: 6926
Accrington
why dont you leave metal where the core is on the rad... and just have it machined out where the fins are?
Ben H
Member #: 184
I have just had my cinqucento rad out. Basic measurements show that the surface area is 96600mm sqd. I then looked at how much material that consisted of and it worked out about 57%. So in theory you only need a hole about 42000mm sqd. This is as I guessed about the size of a number plate, which suits my build.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Sorry i'm being a complete dullard. So you mean that the rear of the rad only needs a 42000mm sqd opening in the cowling?
Ben H
Member #: 184
Well basically yes. There are only gaps for 42000mm of air to go through the rad so any bigger than that behind the rad is not needed, in theory at least.
I always find the best thing is to design things like this as quite restrictive and allow for extra holes to be drilled if it gets to hot. that is how we 'tuned' the cooling on the hillclimber.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Perfect will have a play on the cad program and see what i can come up with.
