| Home > Help Needed / General Tech Chat > Brakes dont work no matter how much i bleed them.. PLEASE HELP! ! ! | |||||||
64 Posts Member #: 5262 Advanced Member Yeovil, Somerset |
29th Jun, 2011 at 07:18:55pm
Hey guys,
1391 Posts Member #: 1686 Post Whore Oxford |
29th Jun, 2011 at 07:27:02pm
Never assume the new component youve just bought works. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
29th Jun, 2011 at 07:33:25pm
Every break has air bubbles?? Or is it just one or two? How are you bleeding them and are you making sure the resivior is properly topped up? Drives
29th Jun, 2011 at 07:42:00pm
what method do you use for bleeding them?
Yes i moved to the darkside |
29th Jun, 2011 at 09:03:41pm
are calipers on the right way up? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 130 Posts Member #: 9395 Advanced Member |
29th Jun, 2011 at 09:18:57pm
On 29th Jun, 2011 robert said:
are calipers on the right way up? A friend of mine did that once - bleed nipples on the bottom of the calipers Edited by ntm1275 on 29th Jun, 2011. |
29th Jun, 2011 at 09:52:29pm
are calipers on the right way up? A friend of mine did that once - bleed nipples on the bottom of the calipers A place claiming to be a tuning shop did that over here too. They had put over 4 litres through them trying to bleed them before someone pointed it out to them !!! needless to say they arent in business anymore. Although their intercooler waterspray that activated the rear window squirters had to be the funniest ! 9.85 @ 145mph
1st Jul, 2011 at 09:41:34pm
Ive bled the rear then the front twice.. Then i tried alternate (front left/rear right/front right/rear left), then i tried clockwise, then i tried bleeding front then rear then letting it settle out over night then bleeding again..
1st Jul, 2011 at 09:44:12pm
Pull the hand brake on and try the pedal,
337 Posts Member #: 9138 Senior Member wolves |
1st Jul, 2011 at 09:59:13pm
mole (pipe clamp is better but any port in a storm)grip a flexi hose and press the brake pedal once and hold the pressure on while getting someone to release the grips and see which one has the most travel |
4th Jul, 2011 at 07:34:10pm
All fixed guys :)
