Home > Beginners Tech > exhaust size help
998-city-rat
Member #: 9421
Bardwell, suffolk
Hi all due to change of plans in engine builds I'm now left with some n/a parts in the garage, would I still be able to use my stainless system with 1.75" I/d on a standard setup metty turbo lump? I have searched and found 2" is best but would hate to have to explain to wifey that I need I new one
jamie@thefatgarage
Member #: 9345
Sheffield
It will be fine up to boost levels that would mean explaining a lot more £££s on other bits to the wife.
998-city-rat
Member #: 9421
Bardwell, suffolk
Cheers for quick reply mate, boost levels? Standard 4psi could it handle more or would it become restrictive?
yeah, that will be fine, start thinking about going bigger at about 8-10 psi
998-city-rat
Member #: 9421
Bardwell, suffolk
Nice one fellas cheers for the help
It will be fine, the only issue it mating it to the 2" downpipe that I assume that you have.
998-city-rat
Member #: 9421
Bardwell, suffolk
i was hoping on using a reducer pipe an flange with my bird poop welding skills should just about pass, just need a down pipe now to fabricate the rest *oh well*
