Home > Help Needed / General Tech Chat > help removing cylinder head, oily water in rad?
c2_mad
Member #: 4215
hi everyone..
tring to get the head of my mini, but one of the rockers wont let me get a socket on the one of the nuts...
what can i do??
Edited by c2_mad on 16th Jul, 2011.
slacken the rocker adjuster off then push the rocker to one side.
c2_mad
Member #: 4215
hi joe, i did try that, but the adjuster didnt budge, i didnt try to hard though..
is there not a way to make the rocker rock? the engine is out as i had problem with the turbo oil drain pipe, if it makes it easier
Amp
Member #: 7856
Turn the pulley on the lower right of the engine, where the fanbelt goes, assuming you haven't disconnected anything it should "rock"
c2_mad
Member #: 4215
great mate... will give that a try...
also i have just realised that i have driven the car for about 100 km with unleaded fuel and no aditive.... what would be damaged and how do i check? i thought te metro turbo was ready to run on unleaded. FML!
cheers
it will be fine,
unleaded fuel causes pitting of the valve seats, but it will take quite a few thousand miles to start to show,
My 1380 is starting to get a little ropy due to this, but i've been running unleaded in it for nearly 5 years, probably about 50000 miles.
c2_mad
Member #: 4215
thank god for that then...lol i was really pissed at myself for a moment.
anyway, head is off, gasket is fine. but the engine is mis firing in cylinder 2 and 3, any ideas?
if you sure the gasket has not blown between 2 and 3 go for plugs, leads, valve clearences etc.....
dont forget to torque your new gasket up to 55ft pounds
Did you do a compression test before you took the head off to see if compression was low on 2 and 3 ???
If the gasket looks good there (although sometimes it's not obvious if it's been leaking) it could be the exhaust valves pitted/burnt. Just because you only did a short distance with unleaded doesn't mean the previous owner didn't do an awful lot more..... leaded fuel hasn't been on the average forecourt for over ten years and the additive is quite expensive.....
c2_mad
Member #: 4215
hi guys...
Been away on holiday for a while, just got back. the headgasket looks brand new. sparkplugs and leads are brand new also benross.
as for the valves i had the head checked not to long ago(maybe 50km back) and the guys said all was fine.
when removing the rad, the coolant was very oily. spoke to a guy and he says it ussually means a cracked block. dont trust his opinion though. any thoughts?
wish i had the money to just start fresh with a brand new engine...FML
c2_mad
Member #: 4215
the engine is also smoking lightly. its was striped down before putting it back in, but the idiot that did the work for me used the old piston rings, bearings etc.. only gaskets were replaced....
knew even less about engines then, than i know now, so took his word that it didnt need anything doing
c2_mad
Member #: 4215
anyone?
