Home > Help Needed / General Tech Chat > Front Mounted Radiator for Clubman
ntm1275
Member #: 9395
Has anybody got any preference or experience of using front mounted rads in a Clubman
The Clubman will still have the inner wings, so there will be a restriction on width, but other than that there is plenty of room
I intend to fit and oil cooler directly behind the grill, with an intercooler down low on the subframe, so that should leave me with enough space to fix a 'Metro size' rad, especially as I'll be also going Megajolt
I have used a Metro rad in the past, but I'm looking for a brand new one, and the Metro ones tend to be a bit expensive these days, so looking for an alternative
Have looked at a Cinquecento Rad, but don't know if this would be up to the job for a turbo motor with over 150bhp, plus I can't find any dimensions to plan my fit
There are a couple on ebay for cheap money (under 30 quid), and the sellers have 100% feedback, so I assume their products must be OK
http://www.ebay.co.uk/itm/FIAT-CINQUECENTO...#ht_2742wt_1163
http://www.ebay.co.uk/itm/FIAT-NEW-RADIATO...#ht_1473wt_1163
But both of these do not appear to have any mounting lugs top and bottom
If anybody has any suggestions I would be grateful, along with the dimensions, and whether they need a separate expansion tank
Edited by ntm1275 on 2nd Jul, 2011.
Cinq rads are a good option,
I'm putting one in my clubman, but the other way round to how you describe. The plumbing is easier that way and you would end up with the highest point in the system being the rad. Probably get air stuck in there and have trouble bleeding it. Pic's of mine here:
http://www.turbominis.co.uk/forums/index.p...d=259072&fr=125
We've also put one in the metro van with 174 BHP and so far all seems well, not done many miles yet, but it hasn't got hot yet. It really struggled with the old MPI rad.
MarkGTT
Member #: 1194
Shropshire.
Both golf and astra rads fit well, although i dont have inner wings i think they would fit in a standard front.
There is a pic of a fitted astra rad in my latest build thread.
Edited by MarkGTT on 2nd Jul, 2011.
ntm1275
Member #: 9395
The old Metro rad had a bleed nipple in the top, so that would be why I had no problem with air stuck in the system
I rather like the way you've got it the other way round, that may be a better option for me
How does the Cinq rad mount, and do you have any dimensions
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
i used to have a vw polo radiator in my old clubman. worked really well.
If i have more toys than you when i die, I WIN
It mounts like this:
The front ended up like this:
I had to add metal to the drivers side mounting bracket bit and a bit at the top of the valance. Dimensions here:
http://www.ebay.co.uk/itm/270681649171
ntm1275
Member #: 9395
Thanks Andy
The Cinq rad seems to be a good way to go
What fan are you using and is it easy to mount to the rad/body?
Edited by ntm1275 on 3rd Jul, 2011.
The fan in the pic is an ebay cheepo, but I've got a kenlowe one now. It's held on with these:
http://www.ebay.co.uk/itm/150620370425
We've got a cheepo ebay one on the van and I don't think it's that effective
ntm1275
Member #: 9395
I didn't know you could get something like that, you learn something everyday
Thanks again
We're using them on the van to hold the rad to the intercooler too, but they're not really strong enough for that.
I attatched my fan to the radiator with some of these - much cheaper!
http://networkcable-tester.com/wp-content/.../cable-ties.jpg
ntm1275
Member #: 9395
Is this ebay link exactly the same as yours as there appear to be two sizes for different aged models
450 x 241 mm
450 x 285 mm
http://cgi.ebay.co.uk/FIAT-CINQUECENTO-99-...#ht_2753wt_1163
Not at home so can't messure it for a few days, but It hink it's the shorter one.
Pictures of both (plus a Mk1 Metro one) near the bottom of this page.
http://www.turbominis.co.uk/forums/index.p...id=356088&fr=25
