Home > General Chat > Good weekend, then not so good, arse
I was at Harewood hillclimb this weekend, had a great practice day, 4 solid runs ending in a 64.66, which was over 1.5s quicker than the class record.
Sadly, when I came to start the car this morning, the ECU was dead, arse. so my times count for nowt and I was left watching .
I guess I can take that the hard work over the winter has paid off, just need to get it sorted for next weekend to make sure I have the first 998 in the 12s!
Curry, beer and Top Gear will be the order of the night.
Bum!
hopfully its something simple.
will, i thought you were in mod prods up to 1400 cc,
Wel mod pro dosen't really exist any more. Its "Modified series production" for normal cars, and "Modified Limited Production" for kit-type cars.
So all the records have been re-set, leaving the door open for Moi. Odly enough the current recod is held by Grahame Russle in a Ginetta G15, which isn't really eligable. But as I'm plenty faster, it makes no differance.
I shall return and steal the record later this year.
Edited by wil_h on 3rd Jul, 2011.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Unlucky wil...good luck on the next outing chap :)
On 19th Jan, 2010 wil_h said:
where does luck come into it,
well done will
Very nice car and should be good at Avon, a 998 in the 12's would be a serious achievement.
frustrating as it is, at least you know the car is performing
Johnny
Member #: 6926
Accrington
what kind of ECU was it?
Specialist Components I would imagine Johnny.
10 years ago i was there with a friend with a lightend mini N/A engine 1293 big valve head and 45 webber etc.... 649 cam and he only was running 73 to 74 seconds ................so this is top stuff wil on that short course
wil when are you attending next ?
64 seconds on the long course, Steve! Next is avon, then Thorsby Park in september, although I may squeeze a Harewood at the end of august.
Right, had time to analise the failure and to make sure it doesn't happen again. It seems that while charging the battery something odd has gone on, a voltage surge while disconnecting is the most likely scenario. This has blown the surge protection rather cleverly incorporated into the power inputs to protect the ECU from such incidents.
It is an SC ECU, and they have sorted me out quick time with getting it repaired. Should have it sorted tomorrow all ready for Avon.
I have also changed the wiring of the battery charging to remove any chance of a repeat. We don't run an alternator, so need to charge the battery a lot.
carl talbot
Member #: 1323
thats a bitch !
'note to self , must get Moggy out next season to give these pesky minis a run for their money !'
not going top happen sunshine, lol
On 4th Jul, 2011 carl talbot said:
thats a bitch !
