| Home > Help Needed / General Tech Chat > gudgeon pins tight | |||||||
4th Jul, 2011 at 06:37:50am
i have put the gudgeon pin on the rod with piston, but is tight on the piston what is the best way to sort this, i have spent about 2 hours moving it back and fourth with little effect. |
4th Jul, 2011 at 04:45:16pm
Big bore, small bore? On 13th Jul, 2012 Ben H said:
4th Jul, 2011 at 04:59:47pm
Out of interest have you tried warming up the piston? I've seent them tight on the pin and when put in front of space heater for literally 10 seconds it becomes free? If something is worth doing, it's worth doing half of. |
4th Jul, 2011 at 05:23:05pm
you will have to remove them and clean the "tad" of swarfe binding it on the pistons clean up using P600 wet and press pistons on using say WD 40
5th Jul, 2011 at 07:30:43am
thanks |
5th Jul, 2011 at 07:47:16am
Have you tried some oil? On 26th Oct, 2004 TurboDave16v said:
5th Jul, 2011 at 08:29:10am
As above, try some heat or lubricate it, it will come. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
