Home > Help Needed / General Tech Chat > few questions relating to corner weights + camber
blister
Member #: 2590
Croydon
I currently have all round adjustable camber and would like to set up the camber on each corner so that i can then sort out how much of my front wheel arch will need to be cut away
but i am not to sure which gauge to get hold of?
also how important is corner weights? and is there a diy version of measuring the weights?
bit of topic here but i recently bought a playmini carbon side exit exhaust and it is no where sitting as high as i thought it would is there away of modding the rear subframe to raise the back box?
If you change the camber, you really need to check the caster too. There is a DIY guide to how to make a caster gauge in PPC this month.
I'm sure there is a way to make your own corner weight gauges using bathroom scales and some lever arangement, maybe google it.
blister
Member #: 2590
Croydon
oh, will have a look at ppc then thanks bud
seen on a different forum a guy used the bathroom scale way to great success
