Home > Help Needed / General Tech Chat > When idling in neutral engine makes a funny whining noise. ANY IDEAS????????
MiniVanMan
Member #: 5262
Yeovil, Somerset
When my turbo mini engine is running at idle it makes a funny wirring whining noise. I think its gearbox related because it happens in neutral BUT NOT when i press the clutch down. ANY IDEAS???
If it helps Ive got a straight cut box (not had one before is it maybe a noise that they just make?)
CHEERS GUYS :)
Kean
Member #: 341
aka T2clubby
South Staffs
Clutch release bearing chap, or straight cut drops if you have them.
Edited by Kean on 4th Jul, 2011.
could it be the idler bearing?
MiniVanMan
Member #: 5262
Yeovil, Somerset
ive tried adjusting the big nut on the end of the clutch/flywheel cover, it makes no difference to the noise..
I dont know if i hve drops or not, i cant remember :/
So do you guys rekon its going to be an engine out job?? (i really hope not)
Kean
Member #: 341
aka T2clubby
South Staffs
Can you post a video so we can hear it?
MiniVanMan
Member #: 5262
Yeovil, Somerset
give me a sec and il get a vid on youtube then post the link :)
MiniVanMan
Member #: 5262
Yeovil, Somerset
http://www.youtube.com/watch?v=4MB9fzIAvbg
Clutch release bearing deffo
MiniVanMan
Member #: 5262
Yeovil, Somerset
Dont like the sound of that 'MikeRace' So are we talking engine out to replace it or something???
I'm not 100% convinced it's release bearing, could be idler or nose bearings. but if these had wear, it would whine as you drove along.
Release bearing is easy to change, follow the Haynes manual to get the wok off to get access to the clutch.
The release bearing would make more noise as you depress the clutch as you load it up. This is not the case here.
It is difficult to judge from the video whether it is the normal rattle straight cut drops make, or whether there is something more sinister. It could be any of the bearings from the idler, to the first motion shaft or deeper.
I would try and get someone who has experienced straight cut gears to have a listen.
Is this a new build, or is it an original build. Has the sound gradually appeared or is this something new to you and never heard it before?
Edited by Sprocket on 5th Jul, 2011.
Its sounds exactly like mine when fittded a duff one, the bearing were all chewed and sitting on the nose of the crank making that noise, but when i depressed the clutch it turned into a faint rubmble.
Yoshimura
Member #: 9204
Amsterdam...Edinburgh
it's your wife moning about all the time and money you stick in that car.....just close the garage door.....the wining noice stops....hahahahhahah *happy*
