| Home > Help Needed / General Tech Chat > New engine, old turbo, smoke when idle | |||||||
28 Posts Member #: 1764 Member |
5th Jul, 2011 at 12:43:53pm
5th Jul, 2011 at 12:47:33pm
Check the things you have mentioned first. If something is worth doing, it's worth doing half of. |
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
5th Jul, 2011 at 01:02:55pm
oil leaking into the cylinder can produce blue smoke out the tailpipe.
5th Jul, 2011 at 03:19:25pm
You can remove one possibility by disconnecting the turbo compressor from the plenum and drive it. It will be SLOOOOOW but you can rule out turbo compressor side oil contamination based on smoke or the lack of it. |
5th Jul, 2011 at 03:19:55pm
Can't you overspeed the turbo doing this? If something is worth doing, it's worth doing half of. |
5th Jul, 2011 at 03:22:21pm
Yes, but I've done it for a quick test before. It's not like it will be doing any hard driving. It would be best not to drive flat out anywhere... just tootle around for a few hundred yards and look out the back for smoke... |
6th Jul, 2011 at 09:09:32pm
Just take the pipe off and look if you suspect compressor side oil contamination, or am I missing something? |
6th Jul, 2011 at 10:01:04pm
On 6th Jul, 2011 metroturbo said:
Just take the pipe off and look if you suspect compressor side oil contamination, or am I missing something? good point
Yes i moved to the darkside |
6th Jul, 2011 at 10:15:29pm
If the engine has been just rebuilt then can I offer the advice I was given - get out there and give it some welly to get those rings bedded in. |
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
7th Jul, 2011 at 01:04:25am
Did it work? I seem to remember tom saying "Run the fucker in" or words to that effect. |
7th Jul, 2011 at 09:13:30am
Like a dream. |
7th Jul, 2011 at 10:48:52am
On 7th Jul, 2011 carts60 said:
Did it work? I seem to remember tom saying "Run the fucker in" or words to that effect. Get the quote right, "run the cunt in" if you don't mind, LOL
