| Home > Help Needed / General Tech Chat > plenum dump valve how to block it off | |||||||
![]() 34 Posts Member #: 9453 Member warwickshire |
5th Jul, 2011 at 12:47:20pm
Hi, i'm fitting an intercooler and a dump valve, I have a montego plenum, do I need to blank off the dump on that, if so how is best to do it (can't weld and my guy is on holiday) |
5th Jul, 2011 at 12:50:46pm
Pack it out with 5p's If something is worth doing, it's worth doing half of. |
5th Jul, 2011 at 12:54:52pm
Cheers that sounds simple enough, even I might manage it. |
5th Jul, 2011 at 12:58:03pm
You could use 20p's if you are feeling flush. If something is worth doing, it's worth doing half of. |
5th Jul, 2011 at 02:51:52pm
Thats more like it, everything else has cost 4 times as much so far |
5th Jul, 2011 at 03:14:28pm
if you wanna do it right grind some £1 coins down and shove them in. If something is worth doing, it's worth doing half of. |
5th Jul, 2011 at 03:49:37pm
Or grind some pennys if your a tight wad... Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
5th Jul, 2011 at 03:59:47pm
Fuck it lets go all out and go with gold sovereigns |
5th Jul, 2011 at 08:12:53pm
the 5p are a perfect fit though lol just use them? Yes i moved to the darkside |
6th Jul, 2011 at 07:22:34am
I have a sandwich plate between the two halves of the plenum to block off the blow off valve.
6th Jul, 2011 at 08:22:36am
cheers for your help, for those going to avon this weekend when you find a load of loose change all over the strip youll know it was me |
1300 Posts Member #: 829 Post Whore essex |
6th Jul, 2011 at 08:23:57am
On 6th Jul, 2011 nearlyfinished said: nice one lol
cheers for your help, for those going to avon this weekend when you find a load of loose change all over the strip youll know it was me 1293 Turbo mini
6th Jul, 2011 at 03:56:59pm
On 5th Jul, 2011 John said:
if you wanna do it right grind some £1 coins down and shove them in. isn't that illegal? On 11th Feb, 2015 robert said:
6th Jul, 2011 at 04:08:18pm
I have a metal bar made for the job that I found in my garage the other day with plunger. Remind me on Fri/Sat and I'll bring it to avon. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Jul, 2011 at 04:15:28pm
have it welded up job done 1293 Turbo mini
