| Home > General Chat > Block Machining | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
5th Jul, 2011 at 01:49:46pm
So I'v literally just pulled out the last of the core and gallery plugs and the block is now totally stripped.
5th Jul, 2011 at 02:43:52pm
All comes down to personal preference, and the healthyness of your bank balnce, you could just get it honed and new rings on std turbo pistons, or go 1293, lightened/balanced rods etc etc. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
5th Jul, 2011 at 03:13:39pm
What engine is it and what are you wanting to do? Your initial post is very vague?
5th Jul, 2011 at 03:22:24pm
Sorry if it was vague!
5th Jul, 2011 at 06:37:21pm
dont bother with the standard metro cam its rubbish in a standard engine
5th Jul, 2011 at 06:54:08pm
You will need to check the crank and bores for size and the crank thrust faces to see whether anything needs boring/grinding. then obviously fit new thrusts, bearings and piston rings.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
5th Jul, 2011 at 06:57:38pm
on this subject what is the sort of top limit size of the std bore that would still allow for a re-hone and new rings? before you would have to go +20? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
5th Jul, 2011 at 07:03:11pm
about 5 thou is regarded as the maximum piston to bore clearence.
5th Jul, 2011 at 07:22:15pm
is that 5 thou diameter or radial? one day boost will be mine!
5th Jul, 2011 at 07:27:24pm
5th Jul, 2011 at 07:31:36pm
so thats per side then? so a max diameter difference of piston and bore of 10 thou? one day boost will be mine!
5th Jul, 2011 at 07:33:56pm
On 5th Jul, 2011 Joe C said:
that clearnce, What he said! I seem to remember it being skirt to bore, but did that engine 4 years ago, so not 100% sure on where it was taken now. On 7th Oct, 2010 5haneJ said:
5th Jul, 2011 at 07:35:21pm
nope you only measure clearance one side, with no gap the other side,
5th Jul, 2011 at 07:36:35pm
and yes skirt to bore, with the skirt measured below the gudgeon pin at the bottom, not on the part of the skirt that wears.
5th Jul, 2011 at 07:41:44pm
im just trying to find out some things that can be measured prior to buying new rings and then finding that the block should of been bored. so the std bore should ideally measure under 5 thou more than the piston. what sort of amount of material is removed when having the bore re honed? Edited by wez on 5th Jul, 2011. one day boost will be mine!
5th Jul, 2011 at 07:51:01pm
a light hone will remove less than half a thou, BUT you need to hone enough to semove any wear marks, which will depend on how worn the bore is....
5th Jul, 2011 at 08:12:15pm
a light hone will remove less than half a thou, BUT you need to hone enough to semove any wear marks, which will depend on how worn the bore is.... the best thing to do is get the pistons measured, and get the bores measured before you do anything, Also on a fresh rebore I have heard of removing 2 thou or more to get a satisfactory bore finish. one day boost will be mine!
5th Jul, 2011 at 08:40:20pm
Lovely. Well i'm taking the block, crank, pistons and rods down to the rebore place tomorrow morning who said they'll check it all over and ascertain what needs to be done to get it back to working nick.
5th Jul, 2011 at 09:10:06pm
On 5th Jul, 2011 carts60 said:
Sorry to be ditsy Wolfie, but i'v always been told the metro cam is quite decent to use? The MG metro cam in the one to use, the standard metro one is bin fodder! On 7th Oct, 2010 5haneJ said:
5th Jul, 2011 at 10:06:23pm
is the only way to actually measure the lobes against cam specification or is there another way to see which I have.
6th Jul, 2011 at 08:34:18am
See here
