| Home > General Chat > The urge to turn up the boost | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
6th Jul, 2011 at 05:00:15pm
How do you fight it off?!
6th Jul, 2011 at 05:03:27pm
JFDI! Whats the worst that can happen? If something is worth doing, it's worth doing half of. |
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
6th Jul, 2011 at 05:06:54pm
ha, yeah what's the worst that could happen, lol |
6th Jul, 2011 at 05:13:31pm
see starmags thread? :) Yes i moved to the darkside |
6th Jul, 2011 at 05:15:00pm
The only way is up.
In the 13's at last!.. Just |
6th Jul, 2011 at 05:16:41pm
On 6th Jul, 2011 theoneeyedlizard said:
for everyday use. good man !! :) Yes i moved to the darkside |
6th Jul, 2011 at 07:33:46pm
I,m sticking to 15/16 psi - at least until I get a new gearbox ! |
![]() 296 Posts Member #: 9117 Senior Member Northampton |
6th Jul, 2011 at 08:15:16pm
how long will the standard box last at 20psi?? Confessed addiction to everything mini |
6th Jul, 2011 at 10:13:05pm
I dont know how long a mini box will last but my guess is not very long. My Ford Type 9 box lasted less than 4000 miles with a lot less than 20 psi |
![]() 825 Posts Member #: 2208 Post Whore Essex |
6th Jul, 2011 at 10:19:57pm
im stuck on 10psi, sometimes turn it down to 8, then back to ten. im not allowed turn turn it up untill i go back to the rolling road, and it helps that the blead valve is under the hood!! :( |
6th Jul, 2011 at 10:38:54pm
I want an electronic boost controler with presets for like eco, fun and bye bye!
6th Jul, 2011 at 11:32:24pm
Boost is like crack, highly addictive! Give in to peer pressure and turn it up :) |
6th Jul, 2011 at 11:47:00pm
Be a man, disconnect the actuator and let the turbo do what it wants. |
7th Jul, 2011 at 07:04:05am
I was at 18psi daily :) an incase bleed valve is not a good idea Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
