Home > Help Needed / General Tech Chat > SC 5 port engine management kit
I know you can run these with forced induction, so i was thinking about it just.
Does anybody use one of these? I was planning on something around 180bhp for my build, would the kit cope with that?
Also, would you need a plenum? As i have a modified montego one this would be perfect if so, if not does the ic pipework run straight onto the throttle body?
Anyone with experience with these would be helpful, by the time ive bought a turbocarb and ignition mapping, i mayaswell get the sc kit and do away with the problems that can arise from using a carb. Cheers
Best off asking SC I reckon.
No you don't need a plenum on this type of TB as the fuel is injected before it seperates to the two ports.
As above, speak to John at SC.
Isnt that exactly what a carb does anyway? Or is there something different to the way in which the fuel mixes? Im guessing the plenum only needs to be there for the float bowl pressurising in which case. Is it john k on here who owns sc, ill drop him a pm if he doesnt see this. Tar
Wil I thought that having an appropriately sized plenum was good for performance?
NickG
Member #: 7912
Australia oi oi oi!
That's what she said :p
You are correct the plenum is there on the carb purely to enable a differential in pressures for the carb to work.
The way I understand it (and I could well be wrong),is that the performance advantage a plenum offers is the creation of equal flow in multiple ports. A single TB into a split manifold, as the SC kit, would not gain any such benefit with a plenum.
When I was orering mine, I asked about the size of the injectors. John said they where good for up to 150ish BHP
If they're what they look like, and knowing what is on my 7-port they are 440cc bosch ones.
I have 4 on the hillclimber though, so 300bhp!!
Unless its cost effective to install larger injectors, it might have to stay carbed as planned, as id like a little provision over 180bhp ballpark, incase i went for a bigger turbo/more boost or the engine produces more power than guesstimated. Its something i wont be purchasing immediately, so the kit may move on from the 150 limit as it stands
Ozyris
Member #: 9054
Disneyland Near Paris
john as give to me the limit of 200bhp max for the stock injector on is kit but after for raise the capacity of the injector two option new injector or put more pression in the injector like an ethanol injection
with 60psi of pressure you injector give 440*1.33=585cc =)
jbelanger
Member #: 831
Montreal, Canada
The increase in flow is not proportional to the ratio of the pressure but to the square root of the ratio. So going from 45 psi to 60 will give an increase of sqrt(1.33) = 1.155 for about 508cc/min.
And you have to make sure your fuel pump can deliver enough fuel at the pressure plus any boost you have.
Jean
http://www.jbperf.com/
Ozyris
Member #: 9054
Yep jean i have mak a mistake of calcul :'(
but you have lot of pump for making more than 60psi if they need
i have myself a SC Kit for turbo so i keep an eye on this topic =)
Wesley
Member #: 9483
If there's a 200bhp limit with the standard injectors from the SC Management kit then I will consider one for my eventual build as 200 is more than enough in a GTM *smiley*
Wesley
Member #: 9483
It does seem a bit pricey though as you could probably replicate it for a lot less. ECU and software does look good quality though.
