Home > Technical Chat > TURBO Weber?
joslin
Member #: 8584
I'm currently building a turbo 998 and i'm wondering if its possible to set up a weber side draft for boost? (blow through) i'm hoping to run 15 pound boost max, and probably 9-10 the rest of the time.
Probably, but not worth the hassle of making it pressurised. a Normal Turbo HIF44 is good for silly amounts of power.
I believe Robert did something along those lines on his turboed V8 TVR (Dribble...)
wez
Member #: 9271
Stoke on Trent
Wasnt the janspeed conversion done with a webber?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
A body of mine did it in the mid ยด90 and it worked ok, but you have to block off the choke.
I dont know if you would get more BHP with a weber set up, but it is not as straight forward as a HIF44
If i have more toys than you when i die, I WIN
basil
Member #: 9458
Hertfordshire
There's a turbo kit on ebay with a DCOE weber 45
Janspeed is a delrotto i belive same as what was used in the old esprit turbos
